Y
yellowvanman
Just replaced some High Bay SONs with some LED High bays, light levels in the middle are fine but levels around the edges are a bit low, where there are carpet displays in cabinets.
Ceilings are very high so using standard wall wash light fittings isn't possible. Anyone got any ideas/experience of improving the lighting around the edges. Display cabinets could extend up to nearly a meter from the wall
Suspended lighting track. Can direct the lamps to where you wish then should they ever change the layout in future.
Just search for track light on whatever website, mains would be my preference as you have a wide selection of GU10 lamps to use with it.
You can be a bit more flash and use wire track, if possible, could be a pain to get it to run with LEDs if you go down that route
