J
Joe1174
Hello, I got to run cat5 cable to 5 data points, do I run 5 individual cables or can I link each data point.
cheers
merry Christmas
individual cables every time. it's not a bloody lighting circuit, is it?
Ha ha reminds me of the time an old spark mate of mine wired cat5 in a ring. Asked me to fit the plates and wouldn't believe me when I told him he'd totally cocked up.
If you don't know exactly where the hub will be make sure you leave long tails where you think if will be!
It is so you can put them on a higher mcb obviously!!!
run a network hub or network switch and 5 separate cables.
wiring them in a ring will not work as you would have data collision
the only ring network type you can run is an arcnet (still used in some industrial networks, primarily for connecting some obsolete equipment)
