D80
What kind of insulation?
Seen it a few times where the polystyrene wall insulation has taken off all the PVC cable insulation. No problem until the cable is moved at all.some of the older wall insulation attacks the pvc of cables. apart from that, as long as the cable is not prone to damage from chafing, should be OK. however, i would drill from by the JB straight through the wall and then run surface outside in black flex.
