Just picked up on this and you are right there is definitely no calibrating going on , my Megger was giving me very low readings on mu checkbox so I took it in thinking it could be adjusted and for £18 seemed too good to be true. It came back out with flying colours not even one digit out of tolerance, it was all done in 5 mins while having a bacon butty.
Because of this I sent my checkbox in for repair to a company in Stafford who then came back to me saying the checkbox was bang on, however I was still getting low results. I sent the megger to them along with the cert and basically what I had been given was a load of rubbish, they said they had seen several of these certificates from cef mainly from CEF own calibration company ACS where every reading was exact to the digit which they say never happens which indicates generic certificates being printed.
On top of this all loop readings were calibrated at 1 ohm, 10 ohms , 100 ohms , 1000ohms which I am told by the calibration company is impossible as no calibration machine on the market does this as they rely on the local loop of the building to start with then there are standard value resistors that increment the value , so loop reference values should be different in every building again proving these certificates are dodgy. I would check yours guys because they may cost £18 but you may as well print them yourself. Ended up costing me almost £200 with the price I paid for initial cal , checkbox cal , then Megger repair / adjustment. The £18 is a con to get you into the CEF store , similarly with free days. Who works for free guys these days. So back to the professionals for me and will never use CEF again
