Spazz
Get yourself a copy of the onsite guide 17th Regs and look at Appendix F
I find it interesting that all the advice revolves around increasing the breaker size and no mention has been made of testing the circuit integrity or that of the whole installation how long ago was a PIR / EICR carried out this could be a loose connection on the wiring or even in the shower itself
If the supply voltage is extremely low due to a DNO fault then that could be the reason ( yes I have seen that one )
It is all to easy in older installations to just up the MCB size without considering other factors like the shower isolator but I am curious about the OP as a 3rd year apprentice I would have expected a bit more knowledge and why post on here and not discuss it with the spark you are working with
