Discuss Changing switch to combo switch/outlet in the UK Electrical Forum area at ElectriciansForums.net
Jabrams86
Hey all - I’m trying to change out a switch only with a combo switch/outlet. After doing the wiring everything seemed to be working but I then realized that the switch also turned off the outlet? Is that normal behavior or did I get my wiring crossed? The combo I’m trying to install has a the standard ground, hot, neutral, and then 2 common (with a thing in the middle that says to break if using 2 circuits.) ideally I’d like a switch and an outlet that operate independtly.
I can tell you that the 2 black screws are for the switch and the gold and silver screws are for the receptacle. I hope this helps and welcome to the forum.
Without the existing wiring not shown we can’t tell you why the receptacle is not working.
Reply to Changing switch to combo switch/outlet in the UK Electrical Forum area at ElectriciansForums.net
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
