The use of plastic or rubber membrane to contain water is simple enough for even me to understand, but shouldn't it be on the outside? In the case of a wet room the walls support the membrane from any water pressure, but how can this work in a basement built below the water table? Does my head in
Hi bud,in the case of a wet room,the tanking or waterproofing,is to prevent the water getting out. This is an easier proposition,as the floor and walls,support the membrane,and any pressure acting on it,by way of hydraulic head.
In the case of a cellar,the treatment or tanking,is there to prevent water getting in. In this regard,it is not supported,other than by adhesion,and will not prevent ingress by way of hydraulic head.
This applies no matter what any salesman or advert will tell you.
It resists against moisture which moves via absorption,migration,osmosis,etc
Any hydraulic head,that is sitting water above such a structure,ground water etc,is coming in. The end.
This is mitigated for,in proper work,by forming a ring channel,behind the tanking/support,which allows any water ingress,condensation,etc,to either drain via gravity,or to a sump arrangement,and then pumped to waste.
Try pushing a 25 litre plastic drum,with the lid cut off,in to a larger tub of water...300mm in and it will fold. What happens to your body,if you dive down to the depth of a cellar?
Remember,head can build up in localised areas,and does not need to immerse an entire property.
You work with nature,not against it,and any product salesman who thinks he has fixed that quandary,is a fool indeed
