I'm always on the look out for a tool that makes the working life easier.
At present, I strip the cable the way I expect most of you do. Side cutters first to snip the end of the cable (exposing the cpc) then pull back the cpc to the required length, then cut off grey outer sheathing, leaving the 3 conductors with just the basic insulation on.
I have no experience with the CK automatic wire strippers, are they worth it? In particular are they quicker than the standard method, also are they easier on the wrists? Or, are they too big and cumbersome and more of a gimmick?
Also, any other automatic wire strippers that are just as good or better?
Oh yes... one last thing.... Can you use them on round flex cable to remove the outer insulation?
www.toolstation.com
C.K Automatic Wire Stripper
Save time while working on electrical tasks using the C.K Automatic Wire Stripper. This versatile product is suitable for stripping both flat and round cables and wires. All it takes is two clicks to remove the outer sheath, as well as extracting the inner conductors in a cable.The tool is...
