O
onions1066
Just wondered if anyone has had any experience with colour changing collingwood lighting before, got a job to start Monday, the kit got dropped off Friday and does not look as straight forward as I was lead to believe. I wanted to run a majority of the time white but colour change on certain occasions. But according to the manual they can't be run on white for too long at any certain time has anyone seen the effects of running them on white for long periods and if so what are the effects. Thanks in advance onions
Not familiar with Collingwood specifically but if it's 'standard' RGB strip we're talking about then that's rubbish. The only thing I can think of is if they are concerned about having all the LED's on (to make white) being too hot for whatever substrate it is that they're sat in.
Depends on whether they are 3 chip (R, G, B) or 4 chip (RGB & W) as to how they produce 'white'. My best guess is that the concern is purely over driving all 3 or 4 chips full-on to make white means that you also produce maximum heat.
Best bet is to talk to their technical dept on Mon and find out what the issue is.
I had some IP problems with them at a hotel swimming pool walkway a few years back.
To be fair it was probably a method of installation problem more than anything.
The fittings were something like 3m appart and were tubed each to the next.
Whoever installed them cut the flexes short and connector stripped a joint to the incoming (and outgoing) wiring.
Water worked its way up the flex and took out the colours one at a time.
In hindsight these should have been individually tubed up the wall to a joint box (dont know the length of manufacturers flex) above the wet line.
Boydy
They problem is if you flex then individually you then need 4 drivers so I'm doing them in pairs. The lead is about 3 meters long so they week be jointed in suitable enclosures.
