Discuss Combi with a 300 litre hot water tank in the Central Heating Systems area at ElectriciansForums.net
I have been asked to provide a wiring centre for a combi boiler providing hot water to two showers a 300 litre hot water tank and central heating. The heating engineer says he is going to provide two two valves. I'm just a little confused as to how the thermostat on the tank will call for the water to be heated. I thought with a combi it relied on water being used, it then provided instant hot water. So I can't see how if the tank cools down how it is going to call for heat, unless its plumbed into the central heating.
Has anyone dealt with this before?
more like a open vented boiler .
S plan the heating
Unvented cylinder will be heated by the heating coil
As the lads have said ignore the hot water side of the combi
Normally fit an unvented cylinder with a combi if they have a big bath or a few baths etc (high draw items)
Bigger question why didn't they spec a system boiler and an unvented cylinder?
I think the landlord has got bad advice. It's a 6 bed HMO, if it was all ensuite he would need the 300 litre tank to run the other showers. As it is I think the tank is providing water to basins, sinks and appliances. Overkill if you ask me. System boiler wasn't specified as the combi was already installed. The heating engineer did question the decision but the landlord was insistent. Ho hum.
If the Landlord has other HMOs then they probably have the best idea of what suits that type of property.
It's his first so I think he has got confused advice. I have a couple of HMO's with a business partner. We use a 300 litre tank when we have 5 ensuites with showers. 2 run off electric leaving the 300 litres tank to deal with the remaining 3 showers. We use a system boiler instead of a combi.
Reply to Combi with a 300 litre hot water tank in the Central Heating Systems area at ElectriciansForums.net
Hi I'm in a bit of a pickle trying to set up my hot water and central heating systems. Got a gas boiler with a pressure tank and a motor...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
