Discuss Commercial swimimg pool pir in the UK Electrical Forum area at ElectriciansForums.net
I was under the impression that swiming pools needed rcd or rcbo protection on all circuits that serve that location or pass through it. Its a commercial pool
But where I am the pool is feed with rcbos from one board but the board that serves the pool underwater lights pool heater and pumps has no rcbo is that correct?
I have seen the previous fixed wire test and it does not even list the board that supplies the pump under water lights and or heater
What supplies this board? There may be an rcd upstream, or there may be a board fed from this with rcd’s then feeding the lights.
thinking the lights are single phase, these are 3 pole mcbs
Board supplied from the main intake i think?
So all the lighting on the room is feed from rcbo
Its just the lights in the pool and the pool heaters and pumps that are not
Reply to Commercial swimimg pool pir in the UK Electrical Forum area at ElectriciansForums.net
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
I need advice regarding an electronic problem on my Hayward Power-flo Matrix pool pump. I notice that : 1. Neutral wire from source has become...
Hi All, We've done some electrical in the past. Wired our outdoor kitchen, added an electric heater to our porch, etc. We are pretty new to pool...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
What are people fitting in the 3 phase range just lately, I've had a scan at various makes and it seems to be a ---- up between Hager and Wylex at...
