gazdkw82
Looking at getting a set of cone step drill bits buts it's a mindfield. So many seem really cheap but promise the world.
All seem to be Chinese produced and labelled as titanium, is there a particular brand, variety that I should be looking at? I always prefer to buy quality for longevity.
Cheap ones are fine for plastic but they don’t last long on metal. Always handy to have though to enlarge holes in trunking etc. For the bog standard size holes in metal I.e. 20mm, 25mm and 32mm I use the armed acceler8 holesaws.
Good cone cutters are helluva expensive and I much prefer the proper hole saws.
Get a quality brand,if choosing a cone type cutter,and save it's life,by changing down speeds,as you step up the size increments.
You can re-sharpen them,but it takes a bit of micro-carbide trickery :)
I will get a decent hole saw set (probably the armeg sheet metal ones) however if I need to step up or a size that's not in the armeg set I'll need a cone drill
I always get mine from Aldi, for enlarging holes they do the job.
They are also cheap enough to not worry if they blunt a bit.
If the pilot is blunt I’ll pilot with another drill bit and enlarge with the hole cutter. It may waste 45 seconds of my day but I make that up by not chewing my food!
