Discuss Confused ...IR readings in the Commercial Electrical Advice area at ElectriciansForums.net
anyone shed some light?
100m run of 4mm nyy cable
New cable and getting 135meg ohm when testing surely this should be >999 on martindale mft
Checked cable and no damage(visual anyway)
I know it's well above minimum permitted but still
So you are testing this with the conductors at both ends free and nothing connected although strictly speaking the cpc should be connected to earth.
Reply to Confused ...IR readings in the Commercial Electrical Advice area at ElectriciansForums.net
I've wired some cable to a small 3x3 shed with 2 gpos, a 15a GPO, and a light. The shed is about 2m away from the house on a concrete slab. The...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Recently changed a CU for a friend and today when visiting one of the RFC's RCBOs tripped. It was due attention anyway as open ring and no time to...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
