Discuss Connector Blocks in the Electrical Forum area at ElectriciansForums.net
R
richtersparty
Hi
When looping in at switches for a lighting cct what size connector blocks do people use for connecting the neutrals as they come in 2, 5, 15, 30 and 60?
If you were using a 6 amp C/B is a 5 amp connector block acceptable.
Also for 1.5mm using a 10 amp C/B would you again use the 15 amp rated block?
thanks
Andy
Hia mate, we use 15a regardless of 5a or 10a. Not very often we have neutrals at the switches only if we are taking a cable to an outside light or something.
Take your connector block outside and throw it as far as you can, then use a modern much more reliable alternative ( in sure push in terminals for instance) that wont work loose, crack because of over tightening etc.:D
do you guys not allready use thease lil beautys?
Thanks for the response guys. Is it frowned upon looping in at switches?
As it happens I'm wiring two bedside lights and spot lights within a bedroom and for testing purposes this seems the best way to do it.
There is nothing wrong with looping at the switches.
As you say, much easier for testing!
Agree with Jason, its easier for testing, and i wouldn,t say its frowned upon at all mate, in the case i mentioned before, outside lights and in your case, nothin at all wrong.
Yeh, totally agree, and down here in rainy/sunny/rainy Manchester we have firms do the same, and we have pulled our hair out when we need to pick up a L/N/E say for an additional outside light or something, and guess what lads, there isn,t one there, its at the bloomin switch and the customer doesn,t want her decorating spoilt, and its that bloomin delf deck(interlocking board) upstairs and a 2min job takes best part of a day.
By the way i have,nt got much bloomin hair left to pull out mind you.
Hi Jason, no, i meant if the lads had wired in and out of light switch, all that would be at the light fitting would be Sw/N/E, therefore you couldn,t get a supply L/N/E for say an outside PIR for eg, via a spur of course mate.
Other alternative would be to spur off a S/O and spur it, but they are not always found on an outside wall.
I do understand there must be a respectable cost saving on cable, would like to know that? but i am a loop in man myself, call me old fashioned but eh! suppose i am.
Reply to Connector Blocks in the Electrical Forum area at ElectriciansForums.net
