B
big-steve
I'm probably going to get shot for this question, but when wiring a contactor/ overload does it matter wich side the supply is connected? I.E into the overload first or into the contactor and out through the overload?
I'm not sure if a thermal overload will work auto reset mode if it's wired in reverse. I'd also say stick with convention, it makes life less complicated and less risky in the long run.
I think it does yes, the load always gets connected to the overload and the mains into the top of the contactor, Out of interest purely for my selfish pleasure, why are you asking about this? short cables and don't want to rewire or crimp out perhaps?I'm probably going to get shot for this question, but when wiring a contactor/ overload does it matter wich side the supply is connected? I.E into the overload first or into the contactor and out through the overload?
I can't see how you can mount the overload module at the top, if it's a conventional starter type unit. I doubt it would fit, and if it did, the ON/OFF control buttons would be out of place requiring, a separate button station next too the starter. If talking about a panel mounted contactor, then yes it could well be mounted at the top, but as others have wisely stated, could or will confuse others after you.
If your having a physical problem with mounting the O/L unit conventionally, rather than trying to accommodate the standard unit at the top, you can purchase stand alone O/L modules that you can mount at the side of the contactor in a panel, or if it's a conventional starter type unit, in a separate enclosure mounted next to the starter... Just all seems a lot of trouble to get around the conventional arrangement... !!!
Not all contactor/overload arrangements are close coupled so the arrangement can get swapped around. But due to convention I wouldn’t recommend going against the norm.
