Discuss Continuity of C.P.C in the Australia area at ElectriciansForums.net
on a new install its important first of all to undertake continuity testing to ensure the circuit has been fully connected and that for example someone hasnt forgotten to connect a socket somewhere on the job which could cause a hazard if energised before proving continuity, along with the other steps of rfc testing aswell as insulation tests, the three step ring final circuit tests also prove the circuit has been connected properly for example has been bridged or connected wrong at one of the outlets,
if its a radial the same applies by completing your continuity test your proving the circuit has been completed and that you dont have any loose connections but again this is for new circuits
only a very brief explanation could go on and on if your unsure on testing you should read or buy gn3 that should help a lot
explain more about the situation is it a new circuit ring radial do you mean r2 as in end to end resistance on a ring so on so on
Reply to Continuity of C.P.C in the Australia area at ElectriciansForums.net
I am wiring up a new kitchen and conservatory. I'm not sure why I checked continuity between line and the metal back box of the light switch, but...
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
I have got these questions on 2391-52 inspection and testing but can't remember option of 1st two questions. Please any suggestion will be...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
