N
Neil2021
Hi
Would really appreciate some advice on this as I have pretty limited electrical knowledge
I live in a fairly new build home with 3 floors and the fuse box can either turn off all the plug sockets on the ground floor or turn off all the plug sockets on the 2nd and 3rd floor in every room
I basically want to be able to switch off sockets or power room by room, basically so I can turn the kids electric off at night to stop them staying up half the night ? without it affecting the other rooms
I've used WiFi plugs (not sockets) but these can be easily overridden or just unplugged, so not much use
What would be the easiest and cheapest way to do this, would it require any kind of rewiring or a new fuse box or circuit breaker?, I have looked at WiFi sockets but most of these can still be switched on and off manually, I did find a lightwave socket that can be controlled by RF and has a child lock but this would need installation and don't know how reliable these would be
Thanks in advance
Without doing some research on this (it's a very unusual request)... I'd suggest that the easiest way to achieve what you want is the Lightwave RF option with child lock. Any 'hard wiring' would be far more disruptive and would need very careful thought and planning... due to a whole host of possible issues.
Would be quite invasive to achieve what you need as the install was not deigned to do this.
I know a few customers whom I have installed a network for turn the WIFI off over night using the setting in the router to stop kids playing games all night.
It appears now that without WIFI nout works.
Thanks, I did try and research online but not a lot of information out there and also asked an electrician, who said to just get a new fuse box but didn't think it would be as simple as that
Would be quite invasive to achieve what you need as the install was not deigned to do when it was designed.
Yeah I imagine it would of needed to be wired up this way from the start, I can turn their WiFi off at night but they can get round that by using mobile data and tethering
You may need a new fuse board to house the additional MCBs for the separated circuit. but the wiring under the floor will need re-configuring.
The only time I have done installs like this are on large mansions.
Would it not be easier to remove all equipment out of their rooms. Splitting the circuits will be a big job.
Yeah it's looking like it will be a lot more complex that I thought, I could take everything out of their room every night but just means unplugging and plugging everything in every day
Then take their mobiles off them at night until they learn. How old are these kids?
Done that before but means doing it every night, older ones are 15 and 17 but got younger ones aswell, but there not an issue, yet ?
You can install remotely switched socket outlets at each point.
So in each bedroom outlet (turn the whole power for the house off first!!!!) remove the existing outlets and fit the replacements (Whatever cables were in L must go in the new L, whatever cables were in N must go in the new N, and whatever cables were in E must go in the new E) - much better to get an electrician to do it.
Then you can download an app to your phone and configure each socket outlet to operate from your phone app.
BG do one, type BG 922HC for a double socket outlet - around £16/17 each I think (edit £15 at screwfix)
You will need to stick to the one make usually, but there are several around.
there are a couple of issues - firstly the cost, and secondly if your kids are smart they could configure it all themselves as well.
Some example instructions attached
I guess you could split that ring into two radials... such that the kids bedroom is at the end of one of the radials... then on the radial that feeds the kids room, find the last socket before it enters that room and replace it with a key switch of some sort.
