Discuss Could someone help with the age of this DB? in the UK Electrical Forum area at ElectriciansForums.net
The protective devices you have are probably BS3871 type C but in some circumstances the white written ones are type 2. You would need to remove each one, type 2 are always printed as such. Some state type C (3871) but if if is not printed assume type C. Crabtree were still producing these up until a few years ago in the guise of 60898 type C they are actually quite rare I've only ever seen one.
Wouldn't you know it. John also posted a video of a C.50 board, albeit a (later?) steel enclosure.
Saw one last week, as above there are quite a lot of them out there.
What was a first for me was finding a 7.5 amp circuit breaker.
Reply to Could someone help with the age of this DB? in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
