Y
yesukannan
Hi all,
why in Current and Voltage Transformer the star point is earthed. that too checking for single point earthing what will happen if there is a duplicate earthing.
thanks
alaguraja
Hi all,
thanks
alaguraja
If the star point is not earthed, it will not be at 0V and then the neutral will not actually be 'neutral' and if a line-earth fault occurs, it is almost impossible for any protective device to operate on a primary fault.
You really need to look at the protection relay manufacturers information.
It’s a vast subject, not one that can be covered in a open forum.
Where do I start with this. You have to sit down and read. Sorry
