W
walec
Hello All, I quoted a job last year which I did not get as I was deemed too expensive. I will try to keep the brief short...The customer was having an extension built. Where the existing CU was in the utility was to be turned into a bedroom so along with the gas I recommended moving the incoming services to the new utility...To cut to the chase got a call last week, could I come and have a look they were supposed to move in in June and its still not finished. First fix is mostly done and found all the cables on an outside wall under a plastic sheet. Looks like rather than move the services or run a sub main they decided to put it on an outside wall. Now whilst I have not seen that done before on a house I guess as long as the CU is in an impact resistant IP rated enclosure its OK (but a potential pain in the arse). Just wondering if anyone had seen one outside before...And then I have to decide if I want to take the job on!...
I hope you have increased your price now, for correcting the previous bodge!:)
You could put a CU outside in an IP44 or better box, however I would not think it sensible or convenient, and terminating all those cables through the box will take a long time.
There will be bound to be corrosion problems late on, but I am sure I have seen various CU's located outside in boxes, normally full of insect and cobwebs!
Good luck and think carefully about accepting.
Closest ive seen is it in a cupboard just outside front door. All element proof though. I did a fuseboard upgrade and was sheltered from the snow and wind was just ******* cold!
got one due...
external dis-board...
Sometimes they build boxes into gable walls on new builds for metering equipment but I'm sure you,d get a board in there too with a bit of precise organising
is it possible, yes, is it practical. nope.
is there any shelter? what it they get a fault and it's pouring with rain and pitch black? just pop outside and reset the breaker....what if it doesn't hold, how many sparks are gonna **** about faultfinding on a job like that!
if it were me i'd take the cables back through the wall and put it in the bedroom
It was a council rewire standard where I used to live to put everything in an external enclosure let into the outer skin of house. Service head, meter and CU with early MCBs. Only needed a triangular key to access.
I recently had the job of removing an up-front RCD in an external cupboard attached to a house (was feeding an swa supply to the house) and installing an RCBO board inside. The customer became terrified when the RCD tripped one evening and they had to go outside in the dark to reset it.
Personally I think it's irresponsible to install a CU outside unless there is absolutely no way of getting it inside.
Regarding it being within regs, then one could argue that the "convenience factor" we all employ by fitting dual RCD boards is somewhat compromised by installing a board outside.
I've come across it on commercial sites where they have houses converted into staff accommodation which are maintained by maintenance personnel. The CU's are usually contained within meter cupboards or other IP enclosures.
Having said that, personally I wouldn't install one externally on a domestic property unless there really was no other option.
Can't be bothered explaining but for reference the installation I am referring to isn't metered as its part of a wider commercial install. If the enclosure is adequately rated for the location and prevents access to unauthorised persons it should be decided by inspector if its fit for purpose.
There is a huge difference between what "can" be done without it being dangerous, and what "should" be done as part of good working practice.
I’ve installed the old style EE Red Spot TP+N DB’s outdoors on overhead crane gantries. They were inside GRP IP rated enclosures with Silica Gel breathers.
Normally I wouldn’t even contemplate it. For a start it would look butt ugly. A MCB trips and you’re out in the rain resetting it. Not a good idea.
Been back to take another look and scratch my head a bit more. I am 6ft 2" and will have to stand on tip toe to reach the switches. It going to have to be surface mounted on the wall in a box and is on the front of the house! No natural cover at all. When I asked the customer why he said he had been told it was not possible to run a sub main to the new utility so the electrician thought it best to put it outside. Closer inspection also revealed the house is a first fix partial rewire. Needless to say interesting to see but time to walk away...unless he agrees to my quotation for a complete rewire...
