- Reaction score
- 8,772
1 - Major supply fault, details unknown. By time I get there DNO already put in genny and are digging up road.
2 - Reason for call, heating not working. I find Horstmann heating controller and Glow-worm boiler completely non functional, I bypass controller and change 630ma fuse on boiler PCB and all comes to life. All three zone valves and pump are working.
3 - DNO repair supply cable, and cut over back from genny to grid.
4 - Fuse on boiler PCB blows a 2nd time when power restored. Boiler was switched off at unit, but not at FCU
Fuse on PCB doesn't blow when heating system energised while calling for heat, tried multiple times.
I'm trying to decide if the direction of travel should be:
1 - high propensity to surges, get an SPD fitted
2 - some intermittent fault on heating system that I've missed randomly increasing draw on boiler PCB, e.g. possibly pump or fan on way out.
Any thoughts? I'm erring on 1 as it seems too much of coincidence.
