Deleted member 26818
I have a helmet cam, which takes a 32Gig micro SD card.It says "requires SD card" so ill have to buy a separate one. Might have an 8Gig kicking around the house
It lasts a few days, before I have to clear it.
I’ve been told it can take a larger size, but you need the 32Gig or smaller to initially set up the camera.
It can be set to automatically overwrite the card, and if you want to save a recording of an incident, you have to tap a button and it will then save what you record, and also the 3 mins before you tapped the button.
