Dan the spark
Evening guys how is everyone?
Am after a bit of advice on a data install, customer wants dual data outlets installed around the house, 12 dual outlets to be exact.
I have only ever pulled the cables to points before and punched down at the outlets so my question is....
What do I need to connect and how do I terminate the other end so that they work?
cat 5 only runs as 1 cable= 1 point. so for a dual RJ45 outlet, you need two cables to it. follow the connection diagram on the back of the socket,but use the B standard. remember, B= British!
as for the other end, it depedns on if you going into a patch panel ect. For a patch panel yopu will have to crimp RJ45 plugs onto the end.
colour code, with the brass facing upwards and away from you is Orange white/orang, green white/blue, blue white/green, brown white/brown
Hi John, yeah I was gonna go for a patch panel, this is the bit that confuses me as haven't had any dealings with that end before
ive only installed the cat 5 cable and terminated both ends. How otys done from there ive no idea. Ibeleive that you plug your broadband line into it, and iot splits the signal, but dont quote me.
There's a few ways of doing it, and ultimately cat5/5e/6 is just a cable, it doesn't really care much if it's high speed data or something to make the boiler run. I tend to do larger installs as 1-1 circuits out in the normal way, then attach to a (12/16/18/whatever) patch bay. The connections for this are exactly the same on the back as for a socket, just more of them. Most of them even have pics to follow! You only need to crimp the plugs if you're making up leads, and it's often cheaper to buy them all nicely done with pretty boots etc than do it yourself.
In electrical terms, just think of them as a number of individual radials all going back to one C.U.
So do I need to run the broadband line into a network switch and the to the patch panel then rockingit?
Erm, kind of depends on the broadband router, but assuming it's the 'telephone-in, RJ45(ethernet) out' type, then you can either connect it direct onto the patch panel (and then the associated outlet into the PC) or connect it onto a network hub/switch and then have the outputs from that device feeding several circuits via the panel.
Also, a lot of broadband routers have multiple outputs on them (typically 4x cat5) - this is doing the same job as a separate hub/switch - so you can just connect those through instead. Just about to leave for a long site day, but when I get back tonight I'll draw up a little old diagram fella to help the explanation!
The fixed wiring will be punched down on the back of the patch panel and the sockets on the front used for the patch cables to connect to routers, switches etc
Sorry chaps, just remembered I said I'd do a diagram - still help anyone if I do?
Hi guys, just finished a small office voice and data cabling, 40 data, 20 voice.
It was lovely work compared to so places i go to. Have to say the little tester i use is brilliant its made by Peak Electrical at Buxton. Out of 640 terminations i got just one pair crossed which the tester picked out. I blame my eyes as they are not as good as they used to be. Anyway got all the data comms gear from Comms express, again brilliant service and good prices.
Basically i terminated all the 40 cables to two patch panels 24way, in the cabinet i have supplied i have left room for the switch, its only a 24 port job so the relevant floor points need pacthing to the switch ports. The servers and router also plug into the switch ports using longer patch leads. Its great work and wish i could do more of it.
