Or even the fact that a charger does not exist at present in the premises would allow if I required by me or client the reason not to change them out. And if charger is installed by someone else then the changing of devices becomes a issue for them to change.
Yes but the circuits that provide sockets etc if there are lots of DC type loads (chargers/laptops etc) it may be prudent, but I wouldn't go with a blanket change no.
Some however use separate magnetic cores and the cancelling out is done on the secondary side via the wiring - this was especially the case for big MCCBs etc.
OK yes the configuration with separate CT's and balance transformer is a problem with circuit currents containing DC and could be blinded here. I've not seen that type of device in a domestic CU so would tend to discount it for the purposes of the OP's situation, but I'm not saying they don't exist.
I agree I realistically picked a poor example, in hindsight I should of stuck to an industrial case - and they haven't been car chargers but other industrial equipment.
Translated it to domestic without really thinking!
