Discuss Did I Do This Right? in the Industrial Electricians' Talk area at ElectriciansForums.net
L
Lul2x
Hey there. I just installed a new light by splitting off of my duplex wall outlet and I was wondering if someone could verify that it is correct. Below is the drawing of what I did. The setup works, I just want to make sure it is safe. Is this good? Thanks for the help!!
Well i would think twice before i shagged it:)
I'd hazard a guess you are in the states?
mdshunks is your man if so, but from a uk sparks perspective;
  1. lack of cpc (earth) to light fitting.
  2. requires a fused spur between light & socket outlet.
Thanks for the replies. I'm from Canada actualy, but our systems are pretty much the same as the US.
It doesn't look like the light fixture has a screw for the ground, just the pos and neg. A fuse would also be a good idea. As the setup is right now, am I looking at any serious safety issues?
Thanks again :)
I don't really give advice to DIY's, but the best place for you to get DIY help for Canadian wiring is Self Help Forums - Powered by vBulletin
Assuming you drew your picture as an accurate reflection of what you actually did, you've got a few problems on your hands. Your house isn't going to burn down today, but it doesn't quite square with the code.
"Your house isn't going to burn down today,"
I am going to remember that quote and if the situation arises will use it myself one day.
Reply to Did I Do This Right? in the Industrial Electricians' Talk area at ElectriciansForums.net
Having to wire around a messed up output for a month or so. Some sort of program corruption is keeping the central lubrication system from...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
DYI guy here with some basic knowledge of electrical craft. I am helping a buddy in his remodeled bathroom. His GFCI outlet was powered off vanity...
