Discuss Disabled hoists in the Australia area at ElectriciansForums.net
G
GIBBOELECT
I have recently been asked to install overhead fixed ceiling track hoists in disabled peoples homes. The instructions that come with the regards to electrical safety are non existant, but the hoists have charger docks which are 240v on the primary side and on the secondary 26--28vdc. The charger then supplies 2x 5.5ah batteries. There is an earth wire on the supply cable but the charger is a class 2 item. I would like to hear other memebers take on the best method of installing these hoists.
It will depend on the unit If the power lead goes right into the unit or does it plug into the unit
if its straight in the Plug top incase anything goes wrong and unit requires replaced then engineers MAY not be allowed to remove from F>C.U.
Reply to Disabled hoists in the Australia area at ElectriciansForums.net
Hi, First post here - so be kind! I'm looking for some advice about the best option for a bathroom LED strip installation. I'm based in Spain...
B
Prefix - I've tried to post this in automotive, but it would not let me. This may be because I have not been recently active. Apologies if this is...
