Discuss Do I need a scheme? in the UK Electrical Forum area at ElectriciansForums.net
Jacko
Hi,
I pretty sure this question has been asked a lot but I can’t find a definite answer so ....
Q1. If I was to start up as a self employed electrician who mainly does property maintenance for a letting agency would I need to be registered with one of the schemes? Most of the work is very small eg changing a faulty pendant, light switch etc 99% of the work is changing items like for like
Q2. I know that certain work is notifiable so I wouldn’t be able to complete that unless I was part of a scheme, contacted BC or was part P? Is that correct?
Q3. If an electrician changed a fuse board for example and didn’t notify BC or register the work through a scheme? What is the outcome because it’s seems to be ‘ok’ years later if a EICR is carried out? If that is the case, what is the point in notifying anyone that the work has been done?
I am a qualified electrician with NVQ 3, 2394, 2395 and 17th edition (will be doing 18th)
The small jobs are a side line from my full time employment so I’m trying to see if it’s worth paying one of the schemes or if it’s possible doing the work without registering with them and just getting myself insurance.
Thanks in advance
if you start off with non-notifiable jobs, hang fire on joining a scheme. if you later find you are getting into notifiable works, then reconsider.
@Jacko I see you're from Wales? If your work is based in Wales, they kept to the 2010 Part P Approved Document, which includes notifiable work, such as in kitchens, garden lighting, supplies to garden sheds etc, which from a personal opinion, England should of done too.
Bear that in mind.
Bear that in mind.
have to disagree there, middy. part pee should be scrapped in it's present form. by making bona fide sparks pay ransom to the scams. it makes us unable to compete with the fly-by-nite bodgers, thus encouraging customers to go with the cheapest price and ending up with unsafe installs.
This 100%
Part pee should be scrapped in its entirety
But it won’t because too many gold plated pensions now rely on it
This 100%
it's stupid.i am not a scam member, but i am registered with local BC's. i can wire a new build entirely, or an extension to a property - no problem. all labc want is a copy of EIC. but if i want to fit a bathroom fan or a shower, , it's £300 before i start, or get a scam member to 3rd party certify. madness.
If membership costed you zero pounds, would you be in disagreement.
Reply to Do I need a scheme? in the UK Electrical Forum area at ElectriciansForums.net
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
Hi, I would like to do some minor domestic electrical work while I am completing my NVQ level 2 in electrical installations. I have the 18th...
5K
I have completed Level 2, currently doing the 18th edition course, I wanted to know, what is it like to get myself into the commercial scene, I...
NICEIC Certification Scheme Getting accredited to
Looking for some advice regarding joining a CPS. I've been in the electrical industry in various roles for nearly 10 years. I started my...
