Discuss Do I need? in the UK Electrical Forum area at ElectriciansForums.net
No, it's not enough to just label up a CU! although that is important. One of the tests of competency is your ability to design a circuit and that does not mean drawing a picture of the cable routes. It's about proving that what you install is appropriate for where it's going and what it's going to do Google circuit design and see what you get.
Yes a durable copy of what is what should be within or near a distribution board but there's more to it than that
The schedule asks for roughly what you say , but it's too much for me to type out cos a can hardly see the reg book marra
What schedule Mate?
As an example, if you're planning a rewire how are you going to justify your cable choice, your OCPDs etc?
There's only one way and that is to do design calculations based on the circuit load, diversity and all derating factors
I know that design calculations and drawings are required and that they should be kept throughout the life of the installation. Rauer asked what the scheme provider would require by way of design of installation and I think what they will require is in the reg number I gave him.
All the boards I have seen with any form of documentation on them are few and far between, but the ones that have had similar to the link he provided. As i was unsure what Elecsa required I suggested that he call them to find out, because I doubt they will want complex equations on an assessment.
I fully agree with you that a full understanding of cable calcs etc is essential in installation work. I think Rauer is capable of doing them, I was'nt suggesting he just marked the board , but follows the guidance of the regs , which I am quite sure he understood .
I'm sorry if I did'nt make myself clear. I'm not about beating the examiner.
Back to the proving unit.
How do you prove any metal parts aren't live before removing covers?
Surely you need to prove your test lamps,test for dead then re prove your lamps.
Before removing any metal db covers.
I thought the idea of it was to prove your meter is working, not to check metal casings were not live
If you carried out a full risk assessment before commencing with any work you would need to prove all exposed metal parts are dead. The only way to do this is with a suitable set of testers. Majority of the time these metal parts are dead hence no voltage will show on your testers so you need to prove your testers are working. I'm aware some testers have a built in proving unit in which case a proving unit wouldn't be required.
what a red herring!. the whole purpose of a voltage tester is to prove that normally "live" parts of a circuit are safely isolated/dead. nothing to do with testing exposed conductive parts of the installation.
Reply to Do I need? in the UK Electrical Forum area at ElectriciansForums.net
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
The breaker pictured trips with nothing plugged into the circuit. It is able to be reset and stays reset for several days, but trips again. When...
I was asked to see why a set of sockets weren’t working in the house (which appear to be a ring circuit based on breakers) There was no power on...
This is confusing, I've ordered a few bits of this stuff, some switch modules and front plates and in the bumf on the website it says:- Click...
