Can a poor connection behind a socket cause the front of the socket to get noticeably warmer without any visible signs of damage?
Would you trust a thermal camera to pick this up early, or would the temperature difference be too small to notice?
Thermal imaging is routinely used to check the condition of live electrical systems and can show faults like poor connections.
However, it’s important to interpret the images with background information about circuit design and loading in mind.
Just because it’s warm, doesn’t mean it’s failing and conversely just because it’s cold, doesn’t mean it’s ok.
Example, a 13A U.K. plug under moderate load will run hotter on the live side than the neutral side because the fuse generates a little more heat than a solid conductor.
I recently got one as a toy and went round looking at everything I could including the charging cable to the EV which was rather warm with 32A flowing through it!, which like you say was totally normal and expected!
it can sometimes be misleading, as each image has a range of colours from, say white, through yellow, and down to blue as coldest....
The difference between the highest and lowest temperatures changes at each image.... it could be 5 to 15 degrees on one image, but 10 to 60 on another.... but the range of colours is the same.
Its how to recognise the differences in colour and understand what could be a problem or not.
Radiator needs bled
