Discuss Doepke Busbar in the The Welcome Forum area at ElectriciansForums.net
Electron
I was unable to add a new MCB (tried CED and MK) to a Doepke consumer unit because their busbar seems to be a unique shape. photo attached. Has anyone else encountered this problem? If so, what solution worked.
After considering that correct above post.If someone were to trim the plastic from the sides of the terminal fixing screw a lot of mcbs could be made to clamp that busbar
most MCBs come with the facility to fit that busbar. some you need to snip out a bitofplastic. or change the busbar to a standard "comb" type.
Reply to Doepke Busbar in the The Welcome Forum area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi all, I needed to replace an MCB for an electric shower with a different rating, it's an older Loadstar consumer unit, and crabtree told me word...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
