metal tables in large kitchen area sockets all protected by rcbos do the tables require earthing your thoughts please
well....i would then....look at a schedule of inspections under additional protection...RCD or supplementary bonding....just a thought though if the sockets were just o an mcb and not rcd protected would that change the sittiuation
but the same could be said for tiled walls Tel.....damp?...IMO , by bonding the tables you make the installation less safe as a person touching the table/s would then be well earthed and as such any shock received could be fatal. TIN HAT SECURELY ON.
i agree that theres times when just indiscriminately earthing something can in fact introduce a potential....so i guess it would go on the individual scenario....OK, but wet is not as good a conductor as steel. and they're more likely to be touching a table than the walls. i,m thinking of the scenario that started the part p fiasco, where she was earthed by her leg being in contact with the casing of a dishwasher.
However, the fact is that there is harm in it.I still see no harm myself though but there we are.
