M Mikro Sep 14, 2012 #1 I wonder where the main earth goes, says I ? ? ? That'll be nowhere then! So the question is, who's fault would this be?
G Guest123 Sep 14, 2012 #3 Doesn't look like thats ever been connected to anything. You could use a constant force spring and braid kit to create an MET to connect the MEC to, assuming it is infact a TN-S supply. I think I would involve the DNO on this one, explain the situation to them and see what they say.....probably tell you to 'TT' it.
O oldtimer Sep 14, 2012 #4 Yep found the same myself but nowhere to connect and because there was an RCD the DNO took their time.
ipf ~ Mentor Arms Sep 14, 2012 #5 Whoever did it. But liability is a different matter now. Get the dno in.
M Mikro Sep 14, 2012 #6 This is in my house, I decided to see what earthing arrangement I had as I progressed through my domestic installer course. I was a little surprised to find this! :annoyed:
M Mikro Sep 14, 2012 #7 DNO should have a record of my earthing arrangement? Am I right? Thanks for replies, bearing in mind I'm a noob, who's expense would this be at?
telectrix ~ Mentor Arms Sep 14, 2012 #8 if there was an existing earth supplied by DNO, either TN-S or TNC-s, then it's their responsibility to maintain it at their cost.
O oldtimer Sep 14, 2012 #9 Mikro said: DNO should have a record of my earthing arrangement? Am I right? Thanks for replies, bearing in mind I'm a noob, who's expense would this be at? Click to expand... Yep but they dont and if there was an earth there they must maintain it if not then ching ching
M Mikro Sep 14, 2012 #10 So basically I ring asking what the earthing arrangement is, they tell me (hopefully), then I break into the old "while we're on the subject .... you're earth is knadgered" ?
