There is no single answer to that.Agree but if there are no codes only C3 then it would be Satisfactory![]()
In the context of the statements from the model form, that is the only logical outcome.Doesn't change the fact it does not say it shall be satisfactory if 1, 2 and FI are not present.
that is an AI generated answer to the question so is worthless.
- Therefore, there is no basis for deeming the assessment unsatisfactory.
Any item raised should be set against the requirements of the Wiring Regulations, not against the inspector’s personal judgement.Coding is the opinion of the person undertaking the job not what some "electrical chat" is telling you. You can chose to make it unsatisfactory even if there are no Code 2, 3 or FI that is your perogative.
A bit of a harsh statement, seems like even if the AI answer is correct in your eyes, it would still be worthless.that is an AI generated answer to the question so is worthless.
Revised FI Code:I did not take from it that FI would now be 'satisfactory' per se. I think that there is concern that the 'industry' uses FI codes too much when they shouldn't be.
I’ve got multi colours in my wardrobe from 15th -18th … some money worth thereAnother amendment…. Another big book.
What colour this time?
Is this a definite future, or some multiversal tangent?
Exactly What I tried to say…Yes!!!Revised FI Code:
The definition of "Further Investigation" is proposed to change from "required without delay" to "recommended". This means that an FI code on an EICR will no longer automatically render the report as unsatisfactory.
Alignment with C3 Observations:
If the proposed changes are adopted, FIs would be grouped with C3 (Improvement Recommended) observations, potentially allowing for a "Satisfactory" outcome, depending on other factors.
Rainbow? That's appropriate..... for Pride month!I’ve got multi colours in my wardrobe from 15th -18th … some money worth there
Brown, Red,Yellow, Blue ..Green any more?![]()
Is that where the saying take pride in your work comes fromRainbow? That's appropriate..... for Pride month!
