Discuss Electrical assignment help in the UK Electrical Forum area at ElectriciansForums.net
sounds right. the pme earth has not been carried into the evcp, which has been made into TT. however, it's a poor diagram as rhe pme earth should proect the cable to the evcp and be halted there.
The supply earthing you have drawn is TNS.
The description correctly describes TNCS.
The charging point is independently earthed of the main installation via a local earth electrode to provide a TT system.
The earth loop will use the ground to provide a return path back to the earthed star point of the transformer.
The supply earth is used to protect the supply cable from DB to charging point but then insulated from the charging point so that the two earthing systems cannot be simultaneously accessible.
The diagram could be changed to something like the below to match the description.
...and link your neutral and earth terms in the SH and meter.
Christmas comes late, eh.
Reply to Electrical assignment help in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone Just looking for some advice and guidance on approaching my HNC in electrical engineering and bridging units. How did other people...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Hello, disclaimer: this is DIY and I am rather ignorant about electrical works. I just moved into a new rental apartment and i wanted to connect...
Hello fellow electricians, Would anyone know how to connect a Nalder Bros & Thompson LTD London, please? ~The BS 89 is a tough book to obtain. I...
Hi Guys Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is...
