P
plugpass
Hi All
Have been busy so not been on site for a while, but as I am here can any one give me some advice on emergancy lighting in a Public House. I have read that the emergancy lighting sign has to be lit at all times but also come on on a back up system when lights go out. Question is can I put the E M on its own circuit as it will still be on if not wired to lighting circuit unless the rcd trips then that bank will go out then the EM will come on its backup system what is the regulations on this matter:blush5:
regards Pete
no problem with it being on own circuit,fit key switch or dp switch for means of isolation.With it being a PH you mite have to use fp200 or micc they are quite stricked on the spec of cable you use.
If the EMG lighting is on the main lighting circuit the emergency lights will come on if there is no power to the other lights, which is what you want. If they're on their own circuit the main lights could go off but the EMG lighting stays in charging mode and with the lights switched off.
Provided the fittings are powered locally (as is usually the case) you should be able to use T&E - if anything happens to the cable the worst that will happen is the light will come on.
Thank you all for such a quick reply on a Sunday Night the fittings I am getting have two circuits in one is mains and the other is battery back up so I think we are ok thanks all for your info and will take on board the switch issue Dave
Regards Plugpass
Plugpass are you saying this pub has it own central battery unit, to power all em lighting...?
a maintained em light fitting connected to the local lighting circuit will do, as this is always illuminated. dont forget to fit a key switch for testing purposes
Got to be maintained fittings he's talking about. Although the pub could have a central battery unit.
Yes but only part of it want to redo all of it as the lighting that is in only comes on when lights go out and in places that sell alchole it should be lit all the time excuse the spelling getting tired.
Is that not what EM lighting is for ?
Presumably not all the time, but when the pub is open, in which case you could just use maintained lights with a switch and a keyswitch.
Ok this is what i thought and just wanted to confirm....would suggest scrapping this on cost value, self contained em lighting will be far cheaper to replace than using existing em UPS.....Self contained is easily wired in T&E as Adam has posted, utilizing the old UPS will mean running any cabling in Piro of FP200 and discharge testing UPS batteries to make sure a 3 hour duration is achieved. A simple T&E via the lighting breaker into a test switch to power all em lighting is far the most cost effective option in my opinion. Hope this helps
I hope you mean local lighting circuit!
