P
Peter Woodford
A friend has just got a flat and asked if I can do a rewire. The thing is it's on the 12th floor and all walls are concrete and the only way I can see doing it is all in mini truncking any throughts
That would be choice,at least you'd have somewhere to hang your washingYou could go with surface stainless steel conduit for that modern look............................................................... if money isn't a problem that is.
Electrix International Ltd - Stainless Steel Cable Management Systems
Hi mac, can you use singles in houses? not been in it long to know??Looks like it's got to be PVC trunking mate,just like council installs.Can you not shove a draw wire up the pipes buried in the walls and pull singles in?
It's a flat on the 12th floor mateHi mac, can you use singles in houses? not been in it long to know??
Thanks Justin![]()
Thanks Justin![]()
