Discuss Extension adapters in the Australia area at ElectriciansForums.net
DaveC1337
Wondering, whats the biggest extension adapter you can get. Or how many you can take from one socket.
I'm organizing a computer event. there will be 30 + computers so I'm wondering how many of these computers can I get on one plug.
I think you will be limited to the maximum plug-top fuse,ie13amp.
But you might have problems with earth leakage.Your 30ma rcd might not be able to cope,it could operate at any level exceeding 15ma.Your supply circuit should also probably be with a high integrity earth connection.If your supply is a radial an additional 4mm earth is commonly used from the last socket to the consumer unit earth bar.You might also have surge problems,so try not to power everything up at once.
Hi,
When you say 30+ how many (if any) will be lap tops, it's only lots of desktops that will cause you problems, first off you will need to get some better idea of the fuse board / circuit layouts of the venue you intend to use.
Reply to Extension adapters in the Australia area at ElectriciansForums.net
I am using a 160watt-200watt multi uv tube stand alone sunbed,When the 2 power leads (plugs protected by 2x13amp fuses) plugged into a double wall...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi guys, We’ve had a new CNC Machine from China arrive this week. It came with a monitor and a tower to run the software. The monitor and tower...
Hi, just hoping for a bit of advice. When I travel abroad (Europe, predominantly Spain/Cyprus) I usually take a single travel adaptor and a UK 4...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
