Discuss extension in the Industrial Electricians' Talk area at ElectriciansForums.net
B
bahco
hi guys
need a bit of help on the following things please
a new extension on the side of my house, the upstairs consist of bathroom onsuite and 1 bedroom.... all the pipework in the 2 bathrooms are plastic, is it best to put all 3 rooms on one lighting circuit protected by a 6a rcbo or 2 bathrroms on a rcbo and the bedroom on a mcb?
next thing shaver socket in the onsuite, ive had a look in the regs but im a bit confused, i would like to fit it above the sink, which is about a metre and a half away from the shower, ive heard something about 300mm away from the sink is that right? if so is that in any direction?
last but not least, bathroom fan, been looking at a manrose inline fan which sits up in the loft, need to know how noisy they are compared to a fan in the wall, and if mounted in the loft do they vibrate a lot?
thanks in advance guys matt
all three on one and rcbo protection as per 17th edition (IMO)
shaver socket is ok in zone 1 (701.512.3)
i used an inline fan in my loft space and suspended it from the rafters on a string of wire ,quiet as the mice up there!!
also used multi gang plug in box rather than jbs etc for all the down lights
also used compact flouri's to save on the energy costs and heat problem
hope this helps
cheers for the reply wayne
i thought all 3 rooms would be ok on the one rcbo just wanted to make sure, as for the fan have you got a cowl in the ceiling or have you got one of those cowls with a lamp in the middle over the shower? sounds like your running gu10's.
reason i ask is the misses wants the cowl in the middle of the ceiling, just wondered how powerfull they are, if they need to be in a certain position.
cheers matt
matt,
one cowl middle of the ceiling above the double shower , 4" inline fan i feel it could be doing with being more powerful as its slow to clear ,two lv dichroics one either side ip rated with tilt
in the general area ive four compact flouris that are the size and shape of a gu 10, aurora range
switches are outside of room
cant speak for the light built into the fan cowl other than the ones ive dealt with have been painful ,get the missus to change her mind:p
the centre of the room it is then, il forget the idear of the light above the shower :)
as for these cfl's its funny because ive heard of them but never fit any, anyway today went to a job and fitted 4 of them.
i really like the light they produce, these where kind of a blue/white light are yours the same?
how do they look when there on with normal 12v lamps?
matt
matt,
Hi Wayne...if they are tilt ....then not IP rated ? Yes ?
T.E.C,
the glass is flush to the ceiling with a sealing ring ,the tilt /pivot is behind ,glass is oval shape to compensate .
if i can find the aurora catalogue ill get you the part number
matt,
mine are "soft white "(cant remember the colour code!!)they take a few seconds to get upto full brightness but are comparable inlight output to normal gu 10's
matt,
ive read something wrong within the regs regarding shaver sockets ;
701.512.3only allows switches of selv circuits to be installed in zone one shaver supply units have to go in zone two 701.32.4 gives a description of zone two
if you now have to remove walls ,sorry but i accecpt no liability on my advice:D:D:D
hi wayne
sorry it took me so long to reply been busy.
ive relocated the shaver socket now so everything is ok, thanks for your help mate
actually there is another thing i wanted to check with you, ive wired the 3 rooms using the loop in and out of the box method, then ive took a 3c+e from the switch to a tp isolator then to the fan.
if i was to replace the normal 1g switch with a dimmer would it still work ok?
ive heard somewere that it wont but cant remember where ive seen it.
thanks matt
Reply to extension in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi i am looking for some advise regarding a bathroom extractor fan currently fitted to my new bathroom refurbishment. Problem i have is a...
Hello everyone, let me begin by stating I am a homeowner after some advice and will in no way be attempting any electrical work my self. We are...
4K
I'm slowly attempting to upgrade and rewire the house I'm in. Started by doing the consumer unit. Got the dno replacing my cable coming as its way...
Hello i've recently just had a re wire done on a three bed semi house, Ive noticed a few things im not 100 percent on ive spoken to the firm that...
5K
