Discuss extractor fans in kitchens in the Australia area at ElectriciansForums.net
B
blenki
Hi , my sister is having a new kitchen fitted soon and i am doing the wiring for it , id just like to check if an extractor fan must be fitted that vents to the outside air , as it stands im not sure on the situation.cheers
hi building regs approved document F states mechanical extract 30 litres above or within 300mm
or 60 litres elswhere basicly you can vent your hob extract to the outside or
fit a 6 inch fan
Agree with old dog.
It should vent to outside air, although it does not have to be the extractor hood over the cooker.
It can be elsewhere in the room but has to have a higher extraction rate, as pointed out.:)
you got a gas hob ??????????
But as this is a new kitchen and not a new build then he can fit what he likes, and Mr building controll can whistle.:)
i done a job new kitchen x council flat client did not want an extract fan building control refused to sign it
off this was not a new build i think the bco was whistling as he left now that you mention it
why was bco involved in fitting a kitchen?
mr building control cant go and whistle cos of part p, new build or not. kitchens like bathrooms are special location so ALL work must be tested and registered, unless you wanna run the risk
Where on your part p certificate is the section for fan type?:)
so as i said in the first place recirculating or external extract, as its not a new build so you can fit whichever you like and mr bco can whistle.:)
(or am i still missing something)
Reply to extractor fans in kitchens in the Australia area at ElectriciansForums.net
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
Just had the following extractor fan fitted for my bathroom, recommended by my electrician. Based on the manual it states the fan should be...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
