ok thanks for the links, but if i cut a 4 inch hole in ceiling, i cant see a possible soloution bar blocking the 4inch pipe and then the fan no good..hmmm building regs book i propbably need
aye its happydays, l-n-e from light fitting to fused spur, then onto fan.. good job, growing in confidince everyday, ****ting meself more and more . thanks
If you put an intumescent seal around the extract duct as it passes through the compartment, then in the case of a fire, the seal will swell and block the duct; true after this the fan would be useless but then again the building has burnt down and may need a new fan!
The building regs book is very good and useful to have but you can get all the information in more detail (sometimes excessive and hard to find detail) from the approved documents available for free download from here Planning Portal - Approved Documents - Downloads
