Fault identification
I’ve been inspecting ground floor switches in 3 year old house for smart relay control installation.
One of the external lights runs has stopped working.
It has 2 switches and I have identified the first switch
All wiring looks well connected in switches. I have not made any changes to the wiring in these switches.
Should I just examine wiring in the lights and ensure waterproof state?
There is a separate 4 gang plate with permanent live running through all 4.
2 of the switches control lights
2 appear to do nothing - they have switch wires coming out. I am concerned these have been missed during build and could be causing a problem as they may have been intended to control 2 separate light runs (1 possibility is the run that’s stopped working).
Thanks in advance.
The say the external lights have two switches, is it two way?
Have you carried out continuity tests on the external lights?
The two switches which appear to do nothing may well control the external lights.
It’s 2-way - There is a switch ( on a 2 gang plate) for the “not working external lights” in each of 2 rooms. Both sets of wiring in the switches look well connected. To be clear it is only just now they have stopped working after 3 years.
I have now checked the 3 external lights and the wiring all looks good. They are led units.
Should I now run a continuity test on these?
Would a failure of one of these cause a problem? Presumably they would in parallel?
I have never found the 2 switches on the 4 gang plate have done anything over the last 3 years and have tried many times. Should I run a continuity test on these as well?
As you know which switches they are you need to do continuity tests. It isn't impossible one of the switches no longer functions.
