Discuss Ferrule Crimps in the UK Electrical Forum area at ElectriciansForums.net
800pcs 10-24 AWG Wire Copper Crimp Connector Insulated Cord Pin End Terminal Ferrules Kit for Electrical Projects
Ferrules
a properly crimped bootlace ferrule, surrounds the cable and increases it’s csa slightly at the point of termination this reduces hot spots at the point of termination.
The 16A you are referring to is AWG or American wire gauge.
Took me a while to find where you were getting 14A and 16A from
Reply to Ferrule Crimps in the UK Electrical Forum area at ElectriciansForums.net
How do you deal with stranded single cable into a MCB/RCBO ? Would you ever ferrule stranded 1.5 or 2.5 singles into a MCB/RCBO ? I can't see a...
4K
Hi all, Hope this thread is still going. I had to cut my stereo antenna cable, so need to reconnect with another cable. I am unsure as the best...
I have a redring water heater with a blown thermal fuse.Trying to keep all original wiring,sleeving etc.Finding it hard to source ferrules to...
Is just twisting the fine wire and doubling it over suitably treated or does it require something like bootlace ferrules? I’ve been using bootlace...
Hi all, Got to look at a job where the builder has cut through the underfloor heating mat and it’s gone right through the heated cable. Not...
