Search the forum,
Discuss Fire Brigade advice in the Electricians' Talk area at ElectriciansForums.net
Not true, the requirement for "non-combustible" CU casings came directly from LFB.
It may have come from the LFB, but it wouldn't have got any traction if the IET and the schemes hadn't encouraged it.
I'm 99% certain that the IET are clutching at straws to come up with more and more regs to justify the AMD's
To get this back on topic. I agree that some protection is better than none, and I don't expect them to fit mains smokes . But I would expect them to advise that the battery ones are a minimum level of protection and explain the choices available.
Small point ....
Most ten year domestic type Smoke alarms ie Aico are presumably called this due to the rechargeable battery lifespan,
yet the actual detection elements are only guaranteed for 5 years after which the element is meant to be tested as per manufacturers guidance,
Yet its a common conception that you can fit and forget for 10 years
People need to check the instructions!
Small point ....
This is the recommended life span of any serviced optical/ion detector, weather aico or professional Apollo/Hochiki. Problem is part 6 domestic, if not serviced/tested correctly, I find pushing a test button a bit hit & miss, and would suggest a correct smoke test be conducted atleast once a year. I would also suggest the battery life, is a calculation only, with alarm activations, reducing the capacity.
Reply to Fire Brigade advice in the Electricians' Talk area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
I'm about to start first fixing this fire alarm in the industrial unit we are wiring, at the moment its totally empty and eventually will have a...
Hi there, Any advice on this would be greatly appreciated! (Note, this is not a DIY, I'm using a fully qualified electrician, just posting here...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi, I need to extend a fire alarm, the panel is a CTEC CFP 2 zone one and currently it has a couple of apollo alarm sense sounder bases/heads on...
4K
