L
lurch
regarding a new supply to a garage. can someone point me in the direction of the regs book or on site guide where it says the rcd protection should be located? In the garage cu itself or a seperate rcbo in the property cu. . .. . . may seem a daft question but need some clarification.
thx in advance
hahahah. . .. just seen a post all about garage suplies and the location of RCDs.
So I recokon the answer to my question is. . . . if I have swa supplying the garage (which I will have)then the swa doesnt need to have rcd protection, because it is mechanically protected, and the rcd can go in the garage, as long as the circuit is on the non-rcd protect side of my consumer unit in the main properrty.
. . . . just to add the cu is a 16th style split with one side rcd protected, and the other side non-rcd protected.
thx in advance
