H
Hellmooth
Good evening, I have bollard style lighting to install in a customers garden, was looking for any ideas that anyone has both for the lights and the installation method.
My current plan is to get bolt down bollard style lights and intall them on breeze block pads with a hole cored through the middle for the cable and sink them into the ground. Was going to use SWA but debating using another outdoor cable without an armour but in ducting, any ideas? Would be to save having to use junction boxes to terminated the armour cable!
Any ideas are welcome, cheers!
Unless its earthed mechanical protection you don't really have a lot of choice other than to use SWA. Gland them in to a Y box at the bottom of the bollard, stuffing gland and flex out to the internal connections in the bollard.
Breeze blocks are a bit soft and porous!
I usually cast a small concrete pad with a duct through the middle of it.
Some fittings often with J bolts and a metal jig which you push into the wet concrete then just bolt the fitting down when dry
Cheers Lee, do you have any links to y boxes and any particular bollards that have decent space in them?
Cheers, this is how I sometimes install electric sliding gate motors!
Soz mate cant post links for some reason....new phone. Just a standard 20mm galv conduit y box with gasket and lid. Last bollards I fitted a few weeks ago were saxby which didn't seem to bad really. As davesparks described they come with J bolts and jig so can be set in to concrete etc.
I did 40 bollards for a showhome, swa in the middle with ducting run just under pad. As lee said conduit y box, armored the bottom and compression gland in the top with a bit of flex. If you want it done quick use wago lever type and dont forget the gasket. Throw the J bolts away and just 3'' screw into the block.
What block did you use?
How will you secure the block? Presumably concrete it in place, so why not just fit the J bolts as it's designed?
Hellmooth,
meridian911,
