L
lucy
Hi everyone, I'm new to the forum and have some questions about garden lighting. Is anyone about at the moment to chat? Thanks
Hiya,
I'm an apprentice electrician and have been asked to do a private job by a friend. recessed spot lights in some decking in their garden.just wondering about the best way to make sure of waterproof connections under the decking. do you know of the best way to do this?
looks like what i'm after thankyou. as a cheaper method would it be safe for me to use a thru box with trs glands for each connection??
Yeah as modernelectric said for any joins, basically you need to look for ip68 rated stuff that way it will be sure to keep water out even when jetwashed
That would be ok too
just like this it possibly wouldnt be enough. You would want to fill the through box with a compound. Go into a wholesalers and ask for some dog****. They will know what you mean. It is a brown compound used for outdoor jointing. Also, if you are using a galv through box, dont forget to use a gasket and to put an M4 screw through the hole in the back of the box. I have been to a few jobs where water has got in this way.
