Discuss Garden Power Lash ... in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
Saw this D.S video on him trying to rectify a fault on a hot tub supply..
Personally I don't think I would have bothered doing all that digging and jointing to try and get the hot tub temporarily back on as
I personally dislike buried joints unless unavoidable.
I would have insisted I run a new feed to the tub
considering the hot tub is 3kw it should be on it own circuit .
and not with every thing else .
In agreeing Buzz, You can't allow for landscapers taking the easy way out to supply everything else, but yes you are correct in your answer.
I hate external landscape electrical jobs, they are never done correctly, works until the first winter then everything leaks, rcd trips out, we get the call to sort it all out
Connectors wrapped in tape and plastic bags ive seen alot lately
I to have found extension leads wrapped in plastic bags , buried taped joints in flower beds etc.
I recently had a job where a customer had spend £1000s on having around 30 stainless steel bollards dotted around the garden.
All wired in 2c 1.5 swa , no earth at any of the lights.
Swa just cut off and all terminated using plastic wiska boxes and a bit of 2c flex.
And this is on million pound houses which have spend ££££s on having their gardens re-done and spend a lot of fancy garden lights etc
Landscapers trying to cut corners and avoid getting an electrician in.
what can you do
Reply to Garden Power Lash ... in the UK Electrical Forum area at ElectriciansForums.net
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hi I am thinking of putting in a Hot Tubat the end of our garden, fed from the a garden shed, more or less next to it, now this might be a silly...
These are going to become the norm aren't they? I've been reading this...
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
