garden-lights1.jpg..
or this
Reactions: 1 person
That would be the Zdb or Zs. The Ze can only be 1 place can it not?
Cannot be arsed to read all the posts on this thread for obvious reasons.
I have, and feel that I have lost 10 minutes of life! :crazy:
i've just connected the megger to my extremities and told 'er indoors to press the --- if i doze off.
Your query- where do I check Ze--Ze is external loop impedance--so its at the DNO service, or more practically-- the distribution board adjacent.
One thing about this thread to some of you know it all type people it certainly caused some interesting results and varying options. Some helpful some sarcastic. We all have various interpretations of the rules and regulations but we are not infallible Is that not why we refer to our on site guides and BS7671:2008 (2011) or even the Electricians Forum. That is excluding the I'm too clever to part with my knowledge or experience. A joke is a joke but bugger a pantomime. Amature armature ha ha armadillos
Any advise on wiring a three pin plug from China from Ebay :fuk2:
No, but I can tell you where to plug it in after you've wired it. :)
Reactions: 1 person
Its what you get from the bank when your account is in credit.
I wouldn't know about that ..... I have more creditors who I pay £1 per month to that the late great Little Waster Bobby Thompson could ever aspire to.
(Google Bobby Thompson ---- Geordie humour at it's finest!)
Well. Some of the so called know it alls clearly know more than you and you haven't answered the point about 2 rcd in series have you?
Reactions: 2 people
right I have been pondering this one and come up with the conclusion we are both right:stooge_curly: , if you look at RCD's they will be in series when in circuit runs through the rcd mcb through the load in series , correct , im happy with that , how ever close the contacts of the switch and mcb's the coils will then be in parallel ,and this is the reason i look at RCD's as being in parallel so the conclusion is rcd's are in the series parallel formation :stooge_curly:rcdschematic.jpg
Reactions: 1 person
It's in series. Numpty. From CU in house to socket in garden to a 13amp plug to shed then into shed CU and RCD and three MCBs. In my book Series. Can't be in parallel as the second circuit would start before first RCD ! Can't remove first RCD because it is protection for outside socket. But to be correct the shed should have had its own supply. But I knew this. So to be safe with the extenson feeding shed CU I wanted to check if there was a problem regarding Ze. So I received abuse from some NHs and some useful information from others. Also quite a bit of disagreement amongst your selves. ?.SELV ?
UOTE=Archy Styrigg;992820]:smilielol5:[/QUOTE]
Reactions: 1 person
Look we all know you shouldn't install 2 RCDs of the same characteristics on the same circuit, we have done this to death 79 posts and still no settled, give it a rest
garden shed Ze
£££sjim,
Guest77,
