G
Guest111
just wiring up my new shed,it's all steel on a concrete base,it's 30 mtrs from the CU and I want 45A.I had some 1.5 t&e which I've run in hose pipe on the surface.It goes from the cutout to a twin socket in the shed,then out of that to a switch to my light fitting.Do I need to stick a rod thingy in the ground for earth,does the light need a fuse somewhere,is there a polarity on an ES lampholder and will my welder run ok on a 13A plug? I don't know the load but apparently it's oil cooled and about 2 feet x 2 feet by 2 feet and goes up to 400A.Also I wanted an extra socket in the house so fitted one in place of a lightswitch I wasn't using,but now the hoover won't work and the light glows faintly,there's a thing on the box keeps flicking down and all my leccy's gone off,this only happened when I dropped my cd player in the bath this morning.I,m an electrician of over 20 years however I don't usually do domestic,I have g&g 2391,17th ed and pat testing,and scheme registered.Can nebdy hlp me cos me toster wont wurk an its duin me hed in,an I won eesy ansers not tellin me to get a spark in wots goin te rip me off an i wont fot no now so urry up.
Well chaps I think I've covered most of the things that wind us up on here and hopefully given you all a chuckle on a Monday morning.ATB Phil
