typical plumber, then. can't see past the end of his nose.
as a gas engineer it should be as near as practicable and preferably not further the 600 mm and before any branch in the installation pipework , as per our regs
It should be a reg that anyone who messes with meters is responsible for ensuring the bonding is correct, sparky, gas or water man. No joint is allowed when looping bond from one service to another.
to be pedantic, you're not allowed to use the screw clamp on the BS951 as a joint between cables. this is so that mr wet-head , when disconnecting a gas bond, does not disconnect the water bond as well ( or vice versa )
I usually run seperate ones but I I don't I will only strip the insulation and loop it through!
But you need to be realistic when you come across situations like this...
He moved the meter causing the problem so (only in my personal opinion) he should also extend/move the clamp or pay for it to be done!
The installer wouldnt of been the one moving the meter, only the transco/national grid can do that.
He could of let it slide, or stuck a recommendation sticker for earth bonding on his report.
Meter not fixed, two flexi tails(can be turned around or laid flat(transco ought to come out and secure with bracket), pipes not clipped, no label for termination way of emergency valve. :)
Are you a gas fitter?
i dont see a problem in you 10mm crimping it heat shrink and extend to <600mm of the meter or entering the building.. if youve been called out to do the job just do it.!
It was for a landlord that has a lot of properties and because of this I don't rip hi. Off for stuff he doesn't need!
he,s a gas man not a sparky. he just knows what he,s told on his one day bonding course. i had one tell me i needed a flex out plate switched from a spur outside the DOWNSTAIRS TOILET TO POWER THE BOILER ABOVE THE TOILET. I TOLD HIM TO F..K off
Perfect ....... they should ALL be like that !! :devilish:
